High beam won't come off
Hi,
I own a 2001 Dodge Ram 1500 Sport and the high beams are stuck on no matter what. I currently have them unplugged because of this, and I tested the voltage with the truck off and locked and the high beam plug is still live with 12.43 volts to it on both passenger and driver side high beam plug. Also, the high beam indicator is on and won't come off either, but if I use the column lever to switch the high beam on and off it seems to work because it clicks and the low beam plug transfers power to the 3rd prong for the high beams like it should. I also tried swapping the fog light relay with the quad high beam relay in the box under the hood, but that did not fix the problem either. If anyone knows what could be causing or have ideas on what to check I would greatly appreciate it! |
Wrong light bulbs ? The Sport uses different bulbs from the other trucks (9007 vs 9004). They look the same at first glance but the filaments are different and more importantly the pinout is different. More info here: https://sparksmith.com/blogs/news/do...and-9007-bulbs
There is always power to the light bulbs by design, the switches connect filaments to ground. |
Originally Posted by DerTruck
(Post 3449880)
There is always power to the light bulbs by design, the switches connect filaments to ground. Wow, did not know that. Will check tomorrow and report back but I am thinking that this is probably the issue. Thanks a lot for this information! |
Originally Posted by boxer15
(Post 3449882)
If the bulbs aren't the problem, it's probably your smart switch. Headlight dimmer, wipers, turn signals all in one. $70-100 at Autozone and $25 up on Fleabay. You don't have to pull the steering wheel. Just disconnect the battery so the air bag doesn't blow up in your face and take the top and bottom steering column covers off. A couple or so bolts and one plug and it will slide right out. I've had several cars and trucks do that and the switch broke inside. |
| All times are GMT -4. The time now is 05:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
