| kelliehallram5.9 |
Jun 22, 2021 10:10 AM |
I've tried everything but still won't start 98 ram5.9l
Ok this all started with a intake gasket change to fix he oil blowing it my tailpipe, guy who did the job wasn't careful and let the back gasket slip while installing and flooded my entire engine within 10 miles truck is down for the count.. I went in flushed the whole system cleaned out oil pan and tube used 5 min flush and cleaned out pan again. Up to that point the truck would start now after I put the pan on I changed the pcv and for some reason the coolant temp sensor had been broke leaving this live wire chilling behind the alternator which of course zapped it a few times. Now no start issue, I've replaced crank sensor, coolant temp sensor distributor and rotor, added an external voltage regulator, ignition coil new plugs and wires, cleaned injectors, made sure it's tdc and checked the cam sensor map and iat sensor. The auto shutdown relay is good fuel pressure is good, throttle is good fixed any grounds I seen that were loose, what am I missing???? codes being thrown are tps high voltage , fuel sender high voltage and temp trans light on dash is on... I just need to know if it's the pcm I'll replace it right now but I'm tired of dumping money in on things that aren't fixing my issue.. I'm getting fuel but no spark someone please help me.
