1500 no signal from pcm to asd
My 2000 Dodge 1500 quit on me and I have traced it back to the asd relay. I have power to the relay (both unswitched and switched) and if I install a jumper wire in place of the two main terminals the truck runs. What I do not have is the ground signal from the pcm to the control side of the asd relay to activate it. I have checked the wire (blue with yellow trace) from the ipm to the pcm and I do have continuity. Is there more I should test or do I need a pcm? Thanks.
Does the fuel pump prime when you first turn the key on? PCM will only engage ASD for about 3 seconds at initial key on, and then, only if it sees the engine turning.
Since it will run with the relay jumpered, likely not a sensor problem. |
Put a voltmeter on the wire just before the PCM. It should read 12V before cranking and go to 0V during cranking when the PCM is supposed to ground the relay circuit. If it doesn't then it's the PCM.
Honestly, I’m not sure about the fuel pump. I will check again at initial key on.
(Post 3577524)
Excellent, thank you. If it doesn’t ground the wire during cranking I will order a pcm.
Originally Posted by tractorsam
(Post 3577531)
Ok, thank you. I used a jumper wire in place of the asd and drove the truck yesterday, seemed to work fine.
