6 inch lift on 37's pictures
Old Aug 3, 2006 | 07:47 PM
20dodgeram01's Avatar
20dodgeram01
Default 6 inch lift on 37's pictures
hey im trying to find pictures of a ram with a 6 inch on 37's.. if anyone on here has any please let me see...how well will the tires fit?? any rubbing??
Old Aug 3, 2006 | 09:03 PM
Big_N_Bad's Avatar
Big_N_Bad
Default RE: 6 inch lift on 37's pictures
I dont think a 6 inch lift will clear 37s maybe if you add that to your body lift to, But i have a total of 10 inches of lift sitting on 38.5 aired to 39s, And they cleared fine with no probelm actually i could have gone with 40s but since i added the bushwaker fender flares they rub when i have it turned all the way, just a little though, i think if you should get the 7 inch lift from sky jacker, they are a good lift and with that and your body lift you could easily clear 37s just a thought, I am waiting on devils reject to resize my pics to fit in the gallery i sent him some through email, hope that helps
BNB
Old Aug 3, 2006 | 11:50 PM
20dodgeram01
i would get a 7 inch but i cant really afford it.. i have a 3 inch suspension lift right now.. i can go for a 3 inch body lift for 6 inchs and maybe fit 37's.. if not then a 36 should fit without rubbing
Old Aug 3, 2006 | 11:54 PM
Tani1500's Avatar
Tani1500
with the proper back spacing you will be fine, you might rub alittle flexing but thats about it. ill try to find some pics for you.
*edit* this is a 4x4 shop by me. the blue one on the page is 6 and 37's http://www.meadowlands4wd.com/dodge.html
Old Aug 3, 2006 | 11:55 PM
GOD RAM IT's Avatar
GOD RAM IT
with 6" of lift I got my 35x12.5 tires to rub. That was flexed up pretty good.
I have a set of 35x14.5 ground hawgs that would fit perfect. they even come with a set of rims.
They measure almost 36 when mounted and aired down to 20 PSI.
they measure more like 12.5-13 wide if you measure just the tread.
