DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Many things done, but finally 1.7's!!!!! (https://dodgeforum.com/forum/2nd-gen-ram-tech/68509-many-things-done-but-finally-1-7s.html)
Silver_Dodge Aug 6, 2006 01:01 AM
Well, I decided to finish up a project (couple actually) that have been laying around in my garage for some time now. So, when I got back from my transmission flush, here's what I did:
- removed my K&N FIPK and cleaned it up (tube and filter). Inspected for cracks, there were none.
- replace my cap and rotor with new one from Summit with brass contacts
- installed a new set of 3923 plugs
- installed my Mopar Performance 7.5mm plug wires
- removed and cleaned the throttlebody and sensors
- checked for plenum leak (luckily none)
- ***removed valve covers and installed my Harland Sharp 1.7 rockers (Finally!!! They've been in my garage for over a year)***.
- installed Mopar Performance valve covers
- replaced my battery with an Optima red top.
- changed the oil
This all took about 7hrs. I'm tired. I took a few pics along the way, but not many because my wife gets pissed when I get dirt or oil on the camera. I'll post what I have tomorrow though.
I test drove it for about 20 minutes. My first impression is that the 1.7's (and the general tune-up) have made a very noticable improvement. My dead spot at lower RPMs seems to be gone. Throttle reponse is awesome, and low end torque seems to be better. I will update after I have driven for a few days, and maybe done my usual drive to work a few times so I can compare the drive I am most used to. Will also update on any MPG changes.
HuntinHanson Aug 6, 2006 01:53 AM
RE: Many things done, but finally 1.7's!!!!!
how was the install for the rockers? pretty simple? are they just bolt on or is it more involved than that?
05SilverHemi Aug 6, 2006 02:15 AM
Are you running the stock cam? I am thinking about installing a set of 1.7's also along with a throttle body and an aftermarket computer.
Tonight I ordered a set of gibson headers, magnaflow cat and a flowmaster cat back. Those rockers might be on the next summit order!
Silver_Dodge Aug 6, 2006 03:36 AM
ORIGINAL: HansonHVAC
Installing is very simple, but getting access to everything is hard. Like the valve cover bolts near the firewall, moving all the hoses and wires out of the way so you can actually get the valve covers off, etc... Once in, installing the rockers is extremely easy.
They are just bolt on. They are self adjusting. All you do is put them on as pairs, tighten them down together, then torque to 21 ft/lbs. Once you do that, they are at the right height, no other adjustments are necessary.
ORIGINAL: 360sport
Yes, you only want to run 1.7's if you have the stock cam. If you go with a cam, then you will stay with the 1.6's. If you decide to get the HS rockers, get them through John at http://www.southeastperformance.com/. His price is hard to beat usually, plus he is a wealth of knowledge when it comes to making power with Magnum engines.
shott8283 Aug 6, 2006 05:50 AM
i was told by my local dealer for HS's that the stocker covers will fit..
ramchrgr88 Aug 6, 2006 01:01 PM
Did you go wth the adjustable ones, or the non-adjustable rockers?? the non-adjustable rockers seem to be a little more expensive then the adjustable ones. Am i right or should i keep looking?
Silver_Dodge Aug 6, 2006 03:37 PM
ORIGINAL: shott8283
Yup, you can use the stock covers, and you don't even need to modify the baffles. I went with the Mopar covers becasue I think they look cool, and figured it was a good time to swap them out since I had my stock covers off anyway.
ORIGINAL: ramchrgr88
Mine are the non-adjustable, i.e. self adjusting. I think they might be a little more expensive. I don't think there is any advantage to adjustable ones. Seems like more to hassle with.
Silver_Dodge Aug 6, 2006 10:04 PM
Well, the picture I took of the rockers installed with the valve cover off didn't turn out for crap, so all I have is the after pictures I took of the engine compartment. Sorry. But, just to prove to you that I really did install them, I took a pic of one rocker that is visble through the oil fill cap hole. :D
[IMG]local://upfiles/9095/DDB5CCD94E06454EAB7651727D643085.jpg[/IMG]
[IMG]local://upfiles/9095/630B14FB1CFE4F48B2FD7EA5B5C16917.jpg[/IMG]
[IMG]local://upfiles/9095/7600919E265C4FF98F1479E7C3D29856.jpg[/IMG]
[IMG]local://upfiles/9095/2F0115F5529943B4A209C7C47F8AB17A.jpg[/IMG]
shott8283 Aug 7, 2006 03:49 AM
i dont belive you!!!! you otta rip them covers and rr's off and send them to me
im jelous... the rr's have been on the back burner for me for quite sometime now... i should start ordering some parts... piss off the wife.. lol
ramchrgr88 Aug 7, 2006 12:45 PM
DO IT!!!!!!!
[sm=goodidea.gif][sm=goodidea.gif][sm=goodidea.gif][sm=goodidea.gif]
that makes me laugh, i should get them too, but im a broke college student, anyone want to help me out with that??
© 2026 MH Sub I, LLC dba Internet Brands
