DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   whistling trans & does'nt want shift when cold (https://dodgeforum.com/forum/2nd-gen-ram-tech/73900-whistling-trans-and-doesnt-want-shift-when-cold.html)
99 RAM Sep 17, 2006 11:04 PM
My tranny whistles when shifting into third. Also it does'nt want to shift into 2nd. for about the first mile . Once the motor warms it shifts fine. I changed the filter and put in a pint of tranz x it helped for a while but problem came back. Any thoughts?
The Burning Rom Sep 18, 2006 12:57 AM
RE: whistling trans & does'nt want shift when cold
Did you check your fluid level?
Also, sometimes...with that trans "fix" stuff, you're supposed to run it for a while and then change the fluid. I'm not sure what the instructions are for that particular one, so you should checkk it out.
99 RAM Sep 18, 2006 08:05 PM
The fluid level is about a 1/4 inch above full. Directions did'nt say to change the fluid after adding tranz x. I put it in a week after changing filter and fluid.
© 2026 MH Sub I, LLC dba Internet Brands
