Ticking sound at 2500 RPM
Old Nov 20, 2009 | 11:39 AM
  #81
Baddnet's Avatar
Baddnet
Still sounds like a wrist pin to me.. rod bearing would have went pretty fast...main bearings would only do it on decel... since it stops when #5 plug wire is removed.. points me back to that piston.. let us know
Old Dec 10, 2010 | 02:33 PM
  #82
LexBeBrolic's Avatar
LexBeBrolic
Man...my truck is doing the same exact thing. I even made a seperate thread about it. I don't know where to begin...
Please let us know what you did to resolve this.
Old Dec 10, 2010 | 03:21 PM
  #83
Sheriff420's Avatar
Sheriff420
Originally Posted by trucklover
We finally tore the engine down last night. Nearly all the rod bearings were severely worn right down to the brass. This engine only has 67,000 miles on it! I was using the Mobile 1 Synthetic oil. None had spun though. I will need to get the crank turned, and I am just going to go thru the entire engine also. I will be putting new heads (EQ heads with 2.02 valves) new cam and lifters (KRC 210x) and also the SCT tune from Hemifever. I am planning on cutting the runners on the intake to compliment the cam and heads.
Old Apr 27, 2011 | 02:34 PM
  #84
lcross2's Avatar
lcross2
Default Ticking noise when accelerating
I have a ticking noise when I ge between 40 and 50. Gets a little louder as you go up hills but not like an engine knock it is like a tick where something is loose or something. I can go over 50 and under 40 and you do not hear it at all. Almost sounds like it is not getting enough gas or something. Has anyone else had this issue?
Just had the O2 sensors changed but still making the noise.
Old Apr 27, 2011 | 03:24 PM
  #85
Sheriff420's Avatar
Sheriff420
Get a mirror and a flashlight (not a mega bright LED light though since it just makes everything white) and inspect the flange where your y-pipe meets the exhaust manifolds along with where the manifolds are bolted to the heads for soot.
You might have an exhaust leak.
Old Apr 29, 2011 | 01:06 AM
  #86
madore33's Avatar
madore33
i have a 1997 dodge ram 1500 with a 5.2 it has 212,000 i have put 3 idler pullies on this truck i have owned it for 5 years..mine was making a tick type sound while idling and driving down the road..just a thought...try pulling the pulley off and check it...
Old Jun 24, 2011 | 05:50 PM
  #87
hbarker's Avatar
hbarker
lordy ,, I hope my ticking ive recently noticed does not turn into a rebuild.. Mercy
Old Jun 25, 2011 | 12:27 AM
  #88
lastrights's Avatar
lastrights
ya does same thing think its time to get new heads and replace llifter pushrods and lifters .
let us know how the qualtity of the heads are along with the ost of doing this project
Old Jun 25, 2011 | 06:05 AM
  #89
neilsrpcustoms's Avatar
neilsrpcustoms
Most of that, if not the lifters, is actualy in the valve guides. SM's say to apply slight side pressure to the valve spring while the engine is running to see if the noise goes away. depending on severity,new valve guides are reccomended. You drive it long enough, and you just won't notice any more.......or.....turn the radio up!
Old Jun 25, 2011 | 02:19 PM
  #90
hbarker's Avatar
hbarker
I just poked around under the hood with a hose to my ear.. I think mine is the fuel injectors.. I hear I can put a quart of atf in the fuel tank?
