stock speakers to new
Alright i've done a lot of reading but never found this. What i want to know is what is the stock wattage on the stock speakers? i have an 06 quad slt. No premium i don't think(not infinity or alpine i think, how would i check that?).
1) if i have a factory amp, it should be under the driver seat correct? 2) 6.5" will be a direct swap? b/c i measured 6.75 and saw that as the measured size as well. 3) the stock set up i have has decent bass, will the kickers have more bass? i know that its all door speakers but i don't need insane bass, just want some more than stock. 4) so if im looking for just a direct swap, what is the best/highest wattage for each speaker to go with? -thanks guys, i've read and have basic understanding. I just want to do a direct door speaker swap since i don't know much about car speaker systems. |
Infinity system say infinity on the speakers and there are tweeters on the a-pillars. Your best bet is to go to crutchfield. Put in your vehicle info and it tells you what fits and what don't fit.
Factory amp is in the kick panel, passenger side from what I remember
thanks guys ill check those things out. its either pistol or speakers for Christmas :)
Not sure about the amp as I didn't have the premium system but you can put 6.5" speakers in, I'm running some 6.5" Polks myself.
I actually did a write-up for the install of the fronts (sadly I forgot to grab pics to write-up installing the rears) which you can find in the FAQ section or just click here. |
Originally Posted by Altair
(Post 2922444)
the rears were zero fun
(Post 2922444)
