Front Tire's
RE: Front Tire's
ORIGINAL: MonkeyWrench4000
Wow Ive never heard of that. How is that caused? The tire is unbalanced so its actually pressing harder to the pavement at a certain spot??
Each wheel position has its own characteristic wear pattern that's determined by the vehicle (suspension geometry, steering geometry, braking action, etc.), the type of driving you do (road surface texture, hills, curves, amount and sharpness of the turns, etc.), and your driving style. If the tire is left in that position, the wear gets exaggerated (irregular).
Rotation causes the tire to develop a different - and usually counterbalanced - wear pattern.
Put another way, rotation doesn't generate even wear, it counteracts irregular and uneven wear.
(found on another web site)
