leveling kit question
i have a 07 dakota and cant find a leveling kit for my year would a 06 one work or should i just wait and how long do you think it would take for a 07 one o come out. Also with a two inch leveling kit could i fit 31s or 32s
RE: leveling kit question
mine are 31's with no lift but had to shave mud flaps
i would like to get A/T also goodwrench A/T or the Dakota A/T would that change anything
My Trail master level kits fits the 2007. No complaint so far about it neither.
would the tires rub if i went with a 16 x 10 rim and 31's with a 2inch TM leveling kit? thanks greatly appreciated it
I ordered the 2 inch leveling kit not too long ago and its on backorder. I plan on going with 32 inch tires probably general AT's using the factory wheels. That is probably the biggest you can go. The 16 x 10 wheels might be too wide or you would need to check the backspacing of the wheel.
ok thank you stock are 16 x8 right?
yea stock wheel is 16 x 8.
