NGK iridium part # for the HO motor
Old 02-13-2009, 03:07 PM
Mahadigus's Avatar
Mahadigus
Mahadigus is offline
Default NGK iridium part # for the HO motor
hey guys I just installed my iridiums in my 07 HO and all i can say is wow dodge should of used these from the factory.
There is a part # difference between HO and non even though ngk's site says they are the same. I called them direct because the HO uses a heat range colder plug then the regular 4.7L.
the correct HO part number is BKR7EIX-11 and the stock number on them is 6988.
hope this info helps
Old 02-13-2009, 05:32 PM
snipingdude's Avatar
snipingdude
snipingdude is offline
Thanks for the info man, I myself am contemplating trying out the NGK, let us know if your mileage gets affected at all for better or worse lol...Hopefully for better =D
Old 02-16-2009, 08:26 PM
newmexicoram's Avatar
newmexicoram
newmexicoram is offline
I be putting my Iridiums in tomorrow morning.
Old 02-18-2009, 08:11 PM
Mahadigus's Avatar
Mahadigus
I'm not expecting any improvements in mileage due to living in Canada and it's the middle of winter, but as soon as it gets above zero and the truck doesn't have to idle for an hour a day I'll be sure to update. The truck does idle smoother and it seems to have more get up and go but that may be that "in the head" feeling so idk lol
Old 02-19-2009, 03:42 PM
dueler320's Avatar
dueler320
dueler320 is offline
Default Well
I put in the new NGK Iridiums and was quite disapointed. They didn't live up to what I had been hearing. Then I read this, go run and grab my box and find what I thought I would. It is the wrong P/N. now I need to go try and convince them on a trade in/return.
Old 02-19-2009, 05:09 PM
mprohr's Avatar
mprohr
mprohr is offline
The non-HO plugs also come pre-gapped at .035 That could make a difference too.
Old 02-19-2009, 10:54 PM
Mahadigus's Avatar
Mahadigus
yep and with the over sensitive knock sensors in dodge vehicles I guarantee it's pinging due to the hotter plug.
Old 02-25-2009, 09:10 PM
dueler320's Avatar
dueler320
Exclamation Gas Mileage
I put in the correct p/n now and still nothing impressive. My mpg has dropped almost 2mpg now. My gaps were all .043. I'm at a loss at what's going on.
Old 02-26-2009, 02:28 PM
Mahadigus's Avatar
Mahadigus
did you reset the pcm to clear all the adaptive memories?
Old 02-27-2009, 01:58 PM
newmexicoram
I bought the NGK's a few weeks back but have yet to install them. So not being a mechanic by any means... What is the pcm? Will I have to mess with that procedure after I install my NGK's???
Quick Reply: NGK iridium part # for the HO motor
