Have you figured out how you are going to run this through the winter months?
The current mixture does not freeze in the dry ice chambers so I think it ill be ok. The colder the alky, the greater the kick when it starts to spray. If it does freeze, I will just run pure alcohol.
When I do go to an intecooler I will keep the meth injection. I will only back of the ammount of spray and it will be pure alcohol. Akly has a high octane and burns super cold.
