power steering noise
power steering makes howling noise when turning sharp in reverse, fluid ok, belt seems ok. also manual says to use atf+4 can i use other types of fluid??? please help
Use what the manual says. To me it sounds as though you have some air in your pump. Check the bleed procedures and give that a try.
only when in reverse? howling? You sure its the pump...
