Motor Swap
Old 04-05-2010, 12:22 AM
Blown287's Avatar
Blown287
Blown287 is offline
Originally Posted by 06dak287
i would say labor wise it wouldnt be worth it for the minimal gain youll get.
This is from Marty at KRC
"Using standard compression pistons, KRC Performances Ported heads, headers and a SCT tune, the New KRC 232 cam will net 360 from the 4.7. Using the Ross forged 11.5 compression pistons and the New KRC 242 will approach 390 rear wheel. I would not be surprised if you see a 5 speed Dakota hit 400+ with that combo."
If that turns out to be true, our engines will be worth the $ if not, definately look into the Hemi swap.
Old 04-05-2010, 12:39 AM
Josh Abels's Avatar
Josh Abels
Josh Abels is offline
I would go with the 5.7 swap. One question I have is r the durangos of u guys' gen like mine were they r basically the same as the Dakota or r they more like the ram then if they r still the Dakota based I'd get a 5.7 outa that it would prolly make it a little easier to swap
Old 04-05-2010, 12:45 AM
hendrixx324's Avatar
hendrixx324
hendrixx324 is offline
i think its more like the ram now
Old 04-05-2010, 12:46 AM
Blown287's Avatar
Blown287
Blown287 is offline
Dusty is the guy to talk to for the 5.7L swap, he is the only person I know that has successfully swaped a 5.7L into a G3 Dakota.
https://dodgeforum.com/forum/3rd-gen...mi-dakota.html
Old 04-05-2010, 12:51 AM
hendrixx324
wow i realy wana do that now
Old 04-05-2010, 12:55 AM
Blown287's Avatar
Blown287
Blown287 is offline
With only a 5.7L(with 6.1L cam) and SCT tune, Dusty ran a 13.9 in the 1/4.
Old 04-05-2010, 12:57 AM
hendrixx324
imagine if he has a supercharger and nitrous
Old 04-05-2010, 01:23 AM
Blown287's Avatar
Blown287
Blown287 is offline
No doubt, what about the 6.4L 392 Hemi in one of our Dakotas, lol?
http://www.thehemi.com/forums/viewtopic.php?p=11569
Old 04-05-2010, 01:30 AM
tdister's Avatar
tdister
tdister is offline
Performing a motor swap on a vehicle, to create something that can be easily and affordably be found as a stock vehicle, would be out of the question for me.
Say you want to sell the truck eventually. I can't imagine wanting to give you the same money an otherwise identical factory equipped V8 truck would bring. I'd need a heck of a bargain to not run away from it.
If you do it, be sure of the vehicle type and year model and try to research any differences (like if it's a jeep 4.7, are they laid out the same?) . Be sure to save the VIN from the donor somewhere too.
I've seen a few swaps done. Be sure to set aside some extra money for surprises along the way.
Quick Reply: Motor Swap
