DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Dakota (https://dodgeforum.com/forum/3rd-gen-dakota-68/)
-   -   I'm about to give up! (https://dodgeforum.com/forum/3rd-gen-dakota/248464-im-about-to-give-up.html)
daytonboy31 Jun 8, 2010 12:03 AM
I wrote about 6 weeks ago about the infamous sticking caliper on my 2005 Dak....I replaced the caliper on my driver side.
NOT FIXED
Along with brake pads.
NOT FIXED
Replaced the rotor
NOT FIXED
What else could it be, still have squeaking, extreme brake dust only on the driver side...
PLEASE HELP
Andrew
ericemery Jun 8, 2010 01:28 AM
did you bleed the brake lines and check the master cylinder?
jkeaton Jun 8, 2010 07:54 AM
yep, what he saids, that's about all thats left or something weird going on with the antilock on that side...
lghtngblt02 Jun 8, 2010 08:33 AM
It takes two people to bleed the bridge well enough unless you have the fancy line bleeder setup :D Pumpi it up release and repeat until everything feels well :D
mprohr Jun 8, 2010 10:32 AM
I love a hard brake pedal.
MonkeyWrench4000 Jun 8, 2010 11:22 AM
Do you have a trusted mechanic? I don't even bother bleeding my brakes anymore after major brake work, I just have my mechanic do it with his line bleeder.
At this point, it may not hurt to have it at least LOOKED at, if you can't figure it out.
Dakkkota Jun 8, 2010 08:40 PM
i had the same problem on my trans am remplace the ruber flexible hose and fix it...
can be something else
projektdirtfab Jun 8, 2010 08:46 PM
did you make sure to put plenty of silicone grease on the pins that slide? could also be twisted brake line from flipping the caliper while it was off causing fluid pressure to hold on that cylinder.
© 2026 MH Sub I, LLC dba Internet Brands
