when your in drive click the od/off or tow/haul button it will shift into 3rd then when you got WOT depending on your speed it will do a 3rd or 2nd gear pull. i found it works much better than flooring it in drive at 70mph
When i'm rolling down the highway at 70 and turn my O/D off and floor it, I redline reeeaaallllly quick
well if you have the right tools i would pull the clip down on the terminal and pull it out, or you can cut it, hope you have a soldering iron and some shrinktube
