DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Dakota (https://dodgeforum.com/forum/3rd-gen-dakota-68/)
-   -   Seatbelt warning won't stop going off (https://dodgeforum.com/forum/3rd-gen-dakota/347365-seatbelt-warning-wont-stop-going-off.html)
Deadsquiggles Jan 25, 2013 10:11 PM
So I've had my truck since last October and haven't had a problem till now. All of a sudden, the seat belt warning will start going off, then stop, the start dinging again.
I tried unplugging the seatbelt wire that runs down from the latch but that didn't work. And I looked in the fusebox but I didn't know which fuse was for the seat belt warning.
Any help would be greatly appreciated.
Thanks,
Tommy
erau Jan 25, 2013 10:39 PM
Try disabling the system entirely:
ENHANCED SEATBELT REMINDER PROGRAMMING
The seatbelt indicator also includes a programmable enhanced seatbelt reminder or “beltminder” feature that is enabled when the vehicle is shipped from the factory. This beltminder feature provides extended and modified visual seatbelt indicator and audible chime warning responses to an unbuckled driver side front seat belt. The beltminder feature may be disabled or enabled by the customer using the programming sequence that follows, or by the dealer using a diagnostic scan tool.
CUSTOMER PROGRAMMING SEQUENCE
NOTE: The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully.
1. With the ignition switch in any position except On or Start, buckle the driver side front seat belt.
2. Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds).
3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
4. Turn the ignition switch to any position except On or Start to toggle the beltminder feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed.
Deadsquiggles Jan 25, 2013 11:30 PM
Awesome, thanks. I'll try it tomorrow morning and see how it works.
calixdakota Mar 21, 2013 05:29 AM
hey if you didint figure out, ill tell you whate happend to me
RIGHT IN THE BUCKLE there is a black and red wire tat u can barely access. like 1mm of each showing, anyway i had one of them get broken, my chime was going off for weeks
i had to get someone to hold the two wires touching to gehtther on the buckle ( very hard) while i clippeed it in an out and turning the key to do the process to disable the chime, i hope i never ever have to do it again it was so hard to get the timing right... i hope that if the batter ever dies, you dont need to disable the chimea gain...maybe if u reset everything though...****
hope you figured it out.
boyceh79 Mar 21, 2013 09:36 AM
Mine does the same thing. I'll def try the reprogramming deal.
jkeaton Mar 21, 2013 10:17 AM
Mine did that. The wonder-engineers at Dodge decided to run the wires for the seat belt warning across the seat tracks to the buckle and after awhile, they get cut in two. I just fished them out from under the truck and wire nutted them together. No more annoying seat belt alarm.
calixdakota Mar 22, 2013 05:19 AM
Yea! i unplugged the connectors too on the seatbelt but it didint make difference. had nothing to work with the re-wire.
Check if it's the wire along the buckel. to the right of where you sit..should see a black and red- hopefully yours isnt cut there...you got less then a MM of wire showing, i was about to smash the ****in buckle apart to get at it , but i said i'd try one more thing. and it worked. like i said i dont think i could pull it off again what I had to do, it was a miracle that what i tried worked.
i wished mine was cut underneath on the electric track for moving your seat around, woulda had a lot more to work with..
Cheers
Deadsquiggles Mar 26, 2013 09:17 PM
I've tried everything listed and still haven't fixed it. What would happen if i pulled the fuse for it?
dakotaff Mar 26, 2013 10:03 PM
Is there a fuse strictly for that? Just a thought, did you disconnect your battery to do a reset. Unplug it for 30 mins and reconnect it. That sometimes clears up all sorts of electrical problems. It can't hurt to try it, it's free.
jkeaton Mar 26, 2013 10:04 PM
You have to short the wires together to turn off the warning. Unplugging the connector will not work. Did you find the two wires and short them together?
These are the wires:
http://i951.photobucket.com/albums/a...ps353e325e.jpg
This is what I did to turn the warning off:
http://i951.photobucket.com/albums/a...psdc693b56.jpg
© 2026 MH Sub I, LLC dba Internet Brands
