1300 quote
I took my 2010 dakota to be looked at the dealership for engine light. They said I needed a
1, tune up 2. New plug wires 3. PCM reflashed 4. missing a ground wire (aftermarket radio was installed with truck when I bought the truck)because my a/c flickers on and off 5. Battery cable needs to be sautered for a new terminal. Why would my pcm need reflashing? |
EDIT: Post removed due to false info contained in it.
If one cracked do I just replace just the coil pack or all 6?
Originally Posted by mku1974
(Post 3117722)
Same year and engine as my truck. They don't have plug wires. No clue when they did away with them, but they have coil packs on top of the plugs.
Originally Posted by djsilver
(Post 3117821)
If it's the 4.7 twin-plug engine (like my friend's 2007) it has a coil pack on the top plug, in the same location as the single plug engines, but the coil pack also has a spark plug wire leading to the second plug near the exhaust manifold.
Not sure what the dealership meant. May have been trying to pull a fast one on you, hoping you didn't know anything about your car (like the average consumer). If one wire/coil was cracked/broken, then you'd need just that coil replaced, not all. How many miles on the truck? PCM may need flashing due to a TSB. They may have updated programming for your engine. |
Originally Posted by cbea1124
(Post 3117686)
no go. we don't have wires..you replace one at a time. never replaced one on mine and I've got 110k
$1300 ? Dam, I'm missing out it looks like! I wondered why I had not become rich by now. I guess because I'm not charging $1300 for a tune up, flash and battery terminals...lol.
PCM flash 1.0 labor (pretty much across the board) Tune up on a 3.7 $129.95... I think. Your 2010 3.7 should have 3 coils and 3 wires. It's a strange setup that they started recently. One side has 3 coils and each coil has a wire going to the other bank. They come 3 to a package for I remember 45 bucks ? Diag labor 1.0..attach the ground that was loose..30 seconds. Part of the diag fee. SOLDER battery terminals?? Mopar has replacements with the stud on them. All you have to do is drill a hole through the flat part of the base of the present ones and attach...IF there is enough "meat" left. |
Originally Posted by TNtech
(Post 3117939)
(Post 3117947)
I retract my first post. I've always been told there are no plug wires on my truck on this forum. After reading your post, I went looking under my hood. There are indeed wires coming off the coil packs on the drivers side of the truck. They run across the top of the engine, but are hidden from sight by the plastic box that connects to the intake and lead to the passenger side plugs.
