285/75/16 tires rubbing on dakota frame.
Hey guys! I was wondering what other modifications needed to be done to fit the 285/75/16's on the 3rd generation Dakota? I have the 3" P.A. body lift, daystar leveling kit and put the 285/75/16 duratracs and I'm getting rubbing on the frame which I didn't expect as the tires/lift sticky thread never mentioned anything about frame rub. If you guys went with*wheel*adapters, which size did you use? If you used new rims which offset/ backspacing did you use?
"" style="border: 0px; vertical-align: bottom;"> |
