2005 dodge dakota 3.7l 4x4
I have an issue..in have a 4speed transmission and when I get to the 4th gear my truck starts hesitate and my rpm just around aliitle and I lose a ittle power. But once I open the trottle up it goes away..just wondering what it.might be..any help is appreciated.
thanks. |
Welcome to DF! Post your questions in the Dakota section.
2005 dodge dakota
(Post 3375940)
You have a manual 4 speed transmission in a 2005 Dakota?
2005 dodge dakota
Originally Posted by jkeaton
(Post 3376071)
There are truthfully quite a few possibilities. It can get expensive just replacing stuff. We will need more information to help narrow it down.
Is there a check engine light on? Has an OBD reader been hooked up to check for and read any codes present? |
Originally Posted by Roldog123
(Post 3376076)
No, It's an automatic. And it' a 4 speed transmission. So when j fetntonthe last year it's starts hesitating but goes away when I open up the throttle..
Originally Posted by FaceDeAce
(Post 3376086)
- spark plugs
- ignition coils - ignition wires - IAT sensor - TPS sensor - MAP sensor - crank sensor - knock sensor - fuel pump - injector - O2 sensor - dead cylinder ... Could start replacing stuff. Gets expensive. Better to come up with a diagnostic plan of attack. When at a loss of where to start or how to check, sometimes it is best to take it to a reputable mechanic to diagnose. Once known, then decide whether to take on the repair/replace yourself or have the mechanic proceed. |
