Help with heater hoses - discontinued?
Hi All,
Hope to get some help with heater hoses... I have a '06 Dakota with 4.7/auto and would like to replace the hoses. No problem with the upper & lower radiator, but having trouble locating replacement heater hoses.
I have been searching around quite a lot and not seeing much info on what Dodge has available, the latest from my inquiry at the dealer is Dodge has discontinued the metal tube/rubber portion of the assembly. The "top" hose from the firewall to the metal tube is available, but the metal tube & OEM fastener & rubber tube to the pump/block in not!!! WTF??? The Dodge dealer said to check out Mitsu for Raider parts... really?!?!?!?!? But that was not much of a help... nothing listed there!
I was thinking about carefully cutting off the lower connector and running just standard old hose from the pump to the tube...
What does everyone do? Thoughts or comments are appreciated!
Am I crazy or just hosed???? hahahahah....
BDG
BDG
Thanks daktwos... I have gone to rockauto and yes there are molded hoses for the portion out from the firewall to the metal tube (front of the engine), that's not the issue. However, my question is from the block/waterpump end up to the other end of the metal tubes. What do people do to replace that section?
Thanks for your input...
BDG
BDG
