Dakota control arms and other suspension
I had my truck inspected at farm and fleet. I need upper and lower control arms and wheel bearings. As well as struts and shocks.
when I look online in find kits with upper control arm but only the lower ball joints. Why don't they come with lower control arms? Also if the kit comes with sway bars and tie rods and such, should I replace all that stuff too.? |
Please add your vehicle details so we know what we are working with.
It is a 2005 Dodge Dakota it has the six cylinder. It is 2 wheel drive. And it doesn't have anything special no power windows or anyting
Wow.
Sounds like you might need something but they don't know what it is so they want to replace everything.
Maybe get a second opinion. |
Is it common to just replace the lower ball joints and not the lower control arms?
Originally Posted by mwb88
(Post 3403352)
I'm in agreement with rodslinger though. I'd consider a second opinion unless it looks really rough under there. |
Nothing wrong with the lower control arms on my family's Dakotas except just needing new Moog lower ball joints and sway bar links.The upper control arms are fairly easy to do if the bushings or upper ball joints go bad if you soak everything good in Kroil for a few days.The inner and outer tie rod ends are easily replaced with common hand tools.
Never really heard of replacing lower control arms unless of performance upgrades or major accident. I'd take the wheels of and inspect all 4 arms and check the geometry by measuring each. Second opinion I'd say. Consider cost and time as well.
For the bearing issue ... rotate the hub and feel/listen for noise, pull on the hub/rotor to see if there is any slop. If yes replace |
