Exhaust power gains
What kind of gains have u gotten on exhaust upgrade. I have 07 4.7HO. I just had a custum dxhaust built that opens up the y pipe into 3" pipe. Straight through exhaust and the dumps in front of rear tire. Id post pic if i could get it to work. Ive noticed much more umpfh when wide open.
Anyone ever had theres dynoed? |
You will get some increase, maybe noticeable. Nothing to write home about unless you start opening the intake and engine. A tuner will make the biggest difference.
Tuner? As in superchips? What about switching out the manifold to a 2008. Any serious gains from that?
Tuner is the best bang for the buck. Yes, superchips is what the majority use. Unless you get bigger valves and pistons (increase displacement), a bigger intake won’t do anything.
Thanks! Is there a tuner as a starting point thatI should start to look at?
Superchips 3865 is what the majority of us used.
Thanks!
