Didn't find this problem on search. Here goes.
Old Dec 6, 2023 | 10:23 AM
LazyGretlWoodWorks's Avatar
LazyGretlWoodWorks
Angry Didn't find this problem on search. Here goes.
2006 Dakota. Just had the whole fuse controller module whatever replaced with a reprogrammed unit, so I suspect I'm just taking it back, but before I do that looking for simple things to check.
The vehicle has no brake lights and the turn signals don't work at the exterior lights although the flasher works (fast like bulbs are out). I suspect they didn't hook something back up, or hooked something up incorrectly (if that's even possible?), but I don't see anything obvious. From what I can see, all fuses are ok. Is there a known thing I should check before just having them come get it and fix it... again?
Thanks much.
Old Dec 6, 2023 | 09:57 PM
LazyGretlWoodWorks
Then later, I went out, and everything is working fine. Found no obvious loose connections, etc., on more checking and looking. Nothing changed other than that it sat overnight. Weird.
