thanks!
i did see the 6 ohm load resistor on their site....and i thought i had to use it for every turn signal bulb i replace. still might try it though.
Originally Posted by coldsteel
(Post 2874276)
You can change your bulbs to LEDs, but you will definitely need a resistor. 6 ohms per side should do it. The computer controls everything and can identify when the circuit is not drawing enough power, indicating a bulb failure, and hyperflashing the LEDs. Just wire the resistor in-line and you will not get the hyperflash or bulb out warning.
You are correct...i edited my earlier response...1 resistor per bulb.
(Post 2874276)
You can change your bulbs to LEDs, but you will definitely need a resistor. 6 ohms per [bulb] should do it. Just wire the resistor in-line and you will not get the hyperflash or bulb out warning.
