DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Durango (https://dodgeforum.com/forum/3rd-gen-durango-154/)
-   -   Nitto's... (https://dodgeforum.com/forum/3rd-gen-durango/373086-nittos.html)
salrt Apr 2, 2014 08:50 AM
Nitto's...
OK, so I am running the Nitto 420s in 285/40/22 and they are driving me nuckin futz! When they are cold I have a pretty decent shimmy in the wheel. Once they warm up it comes and goes (i.e. sometimes I get a shimmy, sometimes it is fine). Had the balance on all 4 wheels re-checked (they have to static balance them since they can only put weights on the insides of the wheels). I just don't get it. I realize I will get more road feel with a lower profile tire, but not a shimmy. I love the look of the Nitto's, but have my tire guy looking at other options as I may $hit can them. Thoughts? Opinions on other tires?
///AMG Hauler Apr 2, 2014 09:47 AM
I have had the same issue from day one both with stock wheels and tires and still with the 22's and Nittos. Much worse the first ten minutes and around 60 mph. some mornings the wheel shakes so bad you can see it clearly with your eyes. Dealer has never been able to "replicate" the issue so I gave up trying. My personal feeling from the way it feels is that the issue is in the rack or column not the wheels.
FSTDANGO3 Apr 2, 2014 10:20 AM
Get them Road force balanced if you can find a place
There have been several post that also indicate that an updated alignment has cured the problem as well. Some of these D's left the factory with alignment off
STEVE
salrt Apr 2, 2014 10:51 AM
Yep, 55-60 is where I have the issue as well. Didn't have it at all with the stock wheels/tires or the stock wheels and Michellin's I put on them. I'll look into that balancing and alignment as well. I really hate to give up the Nitto's as I love the way they look on the truck...
Imamad1 Apr 2, 2014 11:21 AM
1 Attachment(s)
That is an issue with the Nittos. I was looking at those originally, but the place where I bought the tires/wheels said I was going to be much happier with the BFGoodrich G-Force TA. I love them. They are more expensive, but it's the only thing between you and the road. I never skimp on a tire.
And they look killer. I went with a 295 45 20 on 20 x 10 in the rear, and 265 50 20 on 20 x 9 in the front. With the towing I do, I wanted to stay in the 20" wheel, it still looks fantastic.
https://dodgeforum.com/forum/attachm...ine=1396452503
hellomoto_25 Apr 2, 2014 11:42 AM
It's a balance issue. They can road force the wheels and tires. Have it dialed in by somebody that knows what they are doing and it will not be a problem anymore.
Had the same issue with my stock 20" wheels from day 1. Took 3 trips to the dealership to get it right. Magically it was solved after I demanded a rental until it was fixed.
SS2RT Apr 2, 2014 12:52 PM
same here, a proper balance and alignment at a high end equipped wheel shop
(not most dealers) should fix you up
FSTDANGO3 Apr 2, 2014 01:17 PM
Does the guy you recommended still work at that shop close to you
I still need to get to him and get my alignment etc done
STEVE
SS2RT Apr 2, 2014 03:24 PM
yep I think he is part owner and they aren't going
anywhere...if you want to stay while they work male an appt
a couple weeks out so you dont wait long, they are good
at keeping a schedule...
http://www.advancedtireauto.com
ask for Jason, tell him Mike with the 13 Durango sent you..
I think Jason has a '12 or an '11 himself
ufokillerz Apr 2, 2014 03:35 PM
possible that the tire itself is just prone to flatspotting when it sits there for a while?
You mentioned that it comes and goes when its warmed up.
© 2026 MH Sub I, LLC dba Internet Brands
