3rd Gen Durango 2011+ models
The cost of one license plate light bulb on the 2014
Old 06-16-2014, 01:28 PM
depunz's Avatar
depunz
depunz is offline
I don't know how reliable these $65 bulbs are as mine came of the lot with one out. I need to get it fixed asap...
Old 06-17-2014, 08:32 PM
mcfarl58's Avatar
mcfarl58
mcfarl58 is offline
give it time. An aftermarket one will appear soon. Are the Grand Cherokees using the same thing?
Old 06-18-2014, 08:04 AM
GDM's Avatar
GDM
GDM is offline
Did a quick check on license plate bulb on line for my '11 Durango and can obtain for under $10. Perhaps a different bulb, but this aftermarket one is LED. I have not had to replace mine yet.
Old 06-18-2014, 09:11 AM
Wash Man's Avatar
Wash Man
Wash Man is offline
The 14 is completely different, it is a unit. Bulb, circuit board, lens, enclosure....all molded together and you can't take it apart. The unit snaps into the tailgate so the only way you're getting around it would be to cut it open with a Dremel, pull the guts out and put something different in but keep the molded enclosure somehow. Then make sure whatever you put in Is compatible with the amps/volts dodge is sending it.
aftermarket options will be years down the road in this item.
Old 06-19-2014, 07:41 AM
JRRF's Avatar
JRRF
JRRF is offline
On a 2014 this really sounds like a warranty part replacement. No bulb should go out that quickly, and even 3 years from now who's to say it's not the circuit board vs. the bulb? That would still be warranty.
Old 01-18-2015, 08:36 PM
Wash Man's Avatar
Wash Man
Wash Man is offline
Well the one they replaced went out again. Now I'm at 40,000, since it happened before and has been replaced will they cover it?
Old 01-20-2015, 11:40 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
When was it replaced?
Old 01-20-2015, 06:33 PM
Wash Man's Avatar
Wash Man
Wash Man is offline
In June when it was 6 months old around 19,000 miles. Now it is 12 months old and just rolled 40,000 miles
Old 01-20-2015, 08:47 PM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Probably getting wet most of the 14's had a problem with the lic plate lense filling with water
STEVE
Old 01-21-2015, 04:39 PM
lex_durango's Avatar
lex_durango
lex_durango is offline
You'd be surprised, I had a Benz that was similar. I was able to find the LED entire assembly so not only did I get LED but the entire assembly on eBay. See if it uses the same as the Mercedes. You could try to reference the 2008 CL550 which is what I had that required an entire piece.
PS: I wonder if moisture is getting in there hence the frequent burn outs.
Quick Reply: The cost of one license plate light bulb on the 2014
