Water Noise\Sloshing Sound Behind DashBoard?
It shouldn't be that easy to hear, but could be either the washer fluid tank or the radiator expansion tank. Both are under the hood. The only thing under the dash with fluid would be the heater core and if that is sloshing then you would have a plugged line and no heat. Does your heat work?
i have never heard it described exactly that way, but maybe you are hitting the TSB for rattle/squeak/vibration sound coming from dash/cluster/A-pillar vicinity
I have it too, search the forum for the recent threads.
It says fixed in mid 2012 but my late-2012 build / 2013 model def has the issue
https://dodgeforum.com/forum/3rd-gen-durango/333310-rattle-in-dashboard.html
https://dodgeforum.com/forum/showthr...=355430&page=2
https://dodgeforum.com/forum/3rd-gen-durango/336643-rattle-on-supposed-official-tsb.html
It should be fairly easy to correct: fine the drain hose, inset long stiff rod, dislodge blockage. That's it. The problem is that whatever is there is still there, except it it now up in the drain resevoir and could slip back into the drain. A permanent solution would be to remove and clean the drain pan, but that's expensive.
Good luck.
Trending Topics
Water sloshing
I am having this same problem with my brand new 2013 Durango that is only a month old. Sometime it sounded like the water was in the dash or drivers side door. The first thing I noticed was the drivers side floor was wet. Took to the dealership and they said the AC drain line had come loose and they fixed. Took back after I continued to hear the water sloshing and it turned out the AC condensation had drained in a spot under the drivers floor. A plug was removed from under the left side of the vehicle and out came all of the water. The issue I have now is the drivers side floor and the left passenger side floor is getting wet. Now I have to make another trip to the dealership.
Water noise
My 2012 Durango starting making the noise after I got my a/c fixed this summer. It sounds like it’s in the door but I don’t hear if the door is open. Did you ever figure out what it was?
Now, it's possible the water is built up in your door. The water runs down the glass when it rains and drains out through little holes in the bottom. They aren't very big so if any gooky stuff (<---there's that fancy technical term again) plugs them, water will build up. Just play with a tooth pick in the holes and see if there's any water there. Water built up in the doors is not a good thing. It can rust the door out from the bottom or in winter freeze the lock and window mechanisms.
Last edited by ol' grouch; 10-01-2019 at 11:58 AM. Reason: I kant spel wurth a durn
