Tune up on a 2011 V6
Is it just the plenum GASKETS? That's a $15 part. I can see them wanting to change them because you have to remove the intake plenum to change the plugs. The whole intake plenum should NOT need to be replaced unless it was broken.
$300 for the whole job seems about right for a dealer spark plug job. A lot for something you can DIY but about two hours billable labor for a dealer. Sounds about right.
Is it just the plenum GASKET? That's a $15 part. I can see them wanting to change that because you have to remove the intake plenum to change the plugs. The whole intake plenum should NOT need to be replaced unless it was broken.
