3rd Gen Durango 2011+ models
Issues with Trans dropping out of Gear in Reverse
Old 09-24-2018, 02:07 PM
oharag's Avatar
oharag
oharag is offline
Question Issues with Trans dropping out of Gear in Reverse
EDIT: I have a 2015 DD R/T
Has anyone experienced an issue with the GEN 3 DD transmission dropping out of gear? I've had the transmission dropping out of gear while trying to reverse twice yesterday. I put the vehicle dial shifter into R - Reverse. Go to accelerate - there is a large thunk, I stop moving, and the front display and dial flashes. I put in back in P - park, and try again - same issues. I put it back in P-Park and everything works fine. In another incident about a month ago: I put it in R - Reverse and back out of my driveway into street. I put it in D - Drive and apply the accelerator - and the engine revs up but I do not move - the display and dial flash. Put in P- Park, and try again - same issue. Had to wave on another car behind me. After trying a second time everything worked. i"ve had vehicle for 2+ years (purchased used) and only recently experienced this issue. I searched this forum, and Car complaints. Seems like others have had issues with their Trans - but it was thunking between downshifts. Supposedly it was fixed with a PCM update. I recently had my vehicle PCM updated due to two Recalls recently.
Anyone experience this?
Thanks
EDIT: This is the recent recall I spoke about above:
https://www.carcomplaints.com/Dodge/...8v332000.shtml
Old 09-24-2018, 02:39 PM
DDCREW's Avatar
DDCREW
DDCREW is offline
Visit the NHTSA website. Since you mention a rotary gear selector I assume you have a 2014 or later (would be nice if people add their year and model in the "signature" field). There are many complaints about trans shifting out of gear.
https://www.nhtsa.gov/vehicle/2014/D...URANGO/SUV/4WD
Old 09-24-2018, 04:28 PM
oharag's Avatar
oharag
oharag is offline
Thanks for response. I added my year and model to the body of my message. Can't seem to edit the Subject Line.
I looked at the website. Read many rollback issues while in Park. Couldn't find anything specific to failure to engage in reverse or drive.
Old 10-01-2018, 09:20 PM
wi-steve's Avatar
wi-steve
wi-steve is offline
This may be a long shot, but you aren't opening the door a bit while reversing are you, or shifting into gear as you get in before the door is closed? I sometimes open my door while backing my camper into a tight spot (to stick my head out and look back) and since getting the recall on the shifter done that will take it out of gear.
Old 10-02-2018, 12:55 PM
oharag's Avatar
oharag
oharag is offline
No all doors closed.
Old 11-15-2018, 12:01 PM
RamedHemi's Avatar
RamedHemi
RamedHemi is offline
I am having downshifting issue in my 2015 R/T, just had new trans installed and issue still happening, and there are no open recalls. When coming to a stop the truck downshifts hard and the whole truck jerks. Happens often but not all the time. Any insight here??
Quick Reply: Issues with Trans dropping out of Gear in Reverse
