3rd Gen Durango 2011+ models
obd codes po2135,po222,po221
Old May 22, 2026 | 06:54 PM
benenuf01's Avatar
benenuf01
New Member
Default obd codes po2135,po222,po221
2011 durango 3.6l has anyone had this issue
Old May 23, 2026 | 05:59 PM
SHO Rod's Avatar
SHO Rod
The first code you listed, P02135, is an incorrect format. Did you mean P2135? If so, all those codes pertain to the electronic throttle body. It seems likely you have an issue with the electronic throttle body.
What's your comfort level diagnosing the throttle body? Do you have a scan tool that will allow you to monitor the datastream for the ECM and have a multimeter that you know how to use?
-Rod
