Superchips Questions and Updates
#1181
I've only done limited testing so far - was plumber, electrician, painter,... at my daughter's house this past weekend and my son's Blazer is in the shop so he's been driving my truck to work.
I started by loading PT 1-4 up/down RPM Friday evening and BOY DID IT KICK A$$. However, I wanted to start from a known state so Saturday morning I changed all settings to "Superchips". (Three options for each setting Stock, Superchips, and User.) The truck seemed somewhat sluggish after but I want to run it a bit to see if it feels better.
I also re-calibrate the throttle after each tune to get a good base for throttle response.
#1188
As far as safety with the new SC tuning options, let me share this with you guys:
I intentionally tried to "fool" the tuner to see how it would respond. I set my tuner to upshift from 2nd to 3rd with 59% throttle position at 86 mph. I then set it to downshift from 3rd with 59% throttle position at 85 mph. This would have caused an endless loop of upshift-downshift-upshift-etc until the throttle position was changed. Obviously, this would destroy a trans quickly. The tuner did not allow this to occur. It readjusted the 3rd gear downshifts to appropriate levels based on the 2nd gear upshifts.
#1189
As per usual, excellent feedback George!
Sil
#1190
I will be buyin the SC FLASH PLAQ for my 2008 dodge ram 1500 now what i would like to know is the all around best setting is to set up for my truck would be.
Thanks
Thanks
