View Poll Results: Brand of plug your running with:
AC Delco
5
1.12%
Autolite
32
7.19%
Bosch
36
8.09%
53.48%
E3
24
5.39%
NGK
105
23.60%
Other: Please specify in a post
5
1.12%
Voters: 445. You may not vote on this poll
Spark Plugs
Old 06-22-2010, 02:10 PM
magnethead's Avatar
magnethead
magnethead is offline
How do you get to #'s 7 and 8? Seems like they're way up in there?
  #32
Old 07-12-2010, 02:58 AM
popdog's Avatar
popdog
popdog is offline
i changed to ngk v-powers at 36k, very noticable difference in smoothness and the hemi seems to build RPM faster now.. some of the plugs i pulled weren't doing so well
  #33
Old 07-12-2010, 09:32 AM
Horseapples's Avatar
Horseapples
Horseapples is offline
I put an old blanket on the top of the engine and lay on top of it. Pulling the wheel and wheel well liner works as well.
  #34
Old 07-12-2010, 09:35 AM
Horseapples
I use NGK plugs, changed a minimum of onece a year, most years, twice, depending on how hard i run the truck. Great performance with only one melted plug in 4 years. I am very happy with the NGK's
  #35
Old 07-14-2010, 09:30 PM
badblackram06's Avatar
badblackram06
badblackram06 is offline
What would be some recommended plugs for the 4.7L? I've got 58k on mine. I pulled 1 and it was a light light brown color.
  #36
Old 07-15-2010, 06:06 AM
rocket23's Avatar
rocket23
rocket23 is offline
Two #7 inch extensions and a 3 inch extension. plus a swivel I used a spark plug socket and the 3 inch ext. followed by the swivel, And then the extensions. The socket and three inch must be disconnected before the spark plug can be removed from the valve cover well.The same as the next cylinder towards you. Started 4:30 am. with a few beers ,done by 9;30. am.
  #37
Old 08-01-2010, 04:19 PM
xtremekramer's Avatar
xtremekramer
xtremekramer is offline
Well, changed the plugs last night. 4.5 hours later everything was back together. The stealership want $6.95 for the standard champion coper plugs. I bought champion double platinum plugs at advanced auto for $4.60 a plug. Truck is running great today.
  #38
Old 09-03-2010, 12:51 PM
techguy_09's Avatar
techguy_09
techguy_09 is offline
does anyone have a diagram of the spark plugs locations on a 2006 5.7?
  #39
Old 10-20-2010, 09:53 PM
bgbluram2's Avatar
bgbluram2
bgbluram2 is offline
Just changed my spark plugs on my truck. I bought it used with 35k on it about 6 mos ago and wasn't sure if the plugs were ever changed. I pulled them and changed them. They didn't look all that bad, and were only slightly out of gap, but I changed them anyway for peace of mind. Glad I did also because I found two bare injector wires that look like some kind of squirrel or something chewed on them under the intake plenum. Taped them up for now, but am going to get the wires fixed hopefully tomorrow...
I started around 2:30 and finished completely at 6:30 with a lot of patience used!
  #40
Old 11-15-2010, 09:27 PM
comsdude's Avatar
comsdude
comsdude is offline
Default Problem after changing plugs
I just changed the plugs on my 2003 4.7l. Everything went smooth enough and she started right up. However. My wife reports that since the plugs were changed yesterday when she stops to make a turn into our driveway or out of a parking lot (those were the only two instances it has happened so far) the truck just stalls out. No hesitation just stops. I checked all the vacuum hoses and all the connections and everything seems fine. Any ideas?
Quick Reply: Spark Plugs
