Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
- Dodge Ram: Tire Modifications and Size Calculator
Overview of popular modifications to customize your Ram
WHEEL & TIRE FITMENT on DODGE RAM
#31
I have a 2006 ram 4x4 quad cab 2.5 leveling kit by rough country plenty of wheel well space however rubs like crazy on A arm with 35 12.50 R 20s stock rims I ordered a 1.5 " spacer for the rims today I hope this fixes the issue it rubs constantly so something has to work otherwise goodbye 700 dollars for the front two tires they are mts. Hope this helps.
#33
#34
hey guys I hate to be a noob but i really need some reassurance before i go blow my money on non-refundable rims online. I have an 02 1500 4x4 and i just bought some 315 70 17 BF's (thats 34.4x12.4/17)
Now you say i should be able to pull these off if i have rims backspaced 5.5-4.5 right? but you also say the stock rims are backspaced 4.75, would that not mean 5.5 backspaced rims would be even closer to the inside? I'm pretty confused about this one and i'd be infinitely grateful if anyone can give me some guidance!
(i'm looking into some 4.53 backspaced rims with -12 backspacing if its worth anything)
#35
#37
hey
sorry to sound crazy but i have a 2005 dodge ram with stock 17" wheels with 265/70/17 i dont kno what the offset or backspacing is on them but i was wantin to know if a 17x10 alloy ion style 138 wheel with a -38 mm offset and a 4" backspacing will work or will have problems or not? thanks
#38
Hey do you know what the maximum tire fitment for height and width without hitting the ball joint for 2011 Stock Dodge Ram 1500 4wd?
Is it same as 2008's???
34" x 11.5" ??
same as 2008's???
Thanks-
34" x 11.5" ??
same as 2008's???
Thanks-
#39
Im concerned about the tire width height im not to worried about but width i am! I have read everything over and over again and im even more confused with all this info in my head so i need help lol! I have a 2007 dodge ram 1500 with lvl kit and im using stock rims and i want to put 35x12.5r17 Trail Digger M/T on her so if anybody has this set up and has run tires like these on there truck let me know and if these wont fit any suggestions would be welcome! Thx again for the help!
#40
Stock everything...fitment is limited to width on these trucks more than height with stock wheels. 34" x 11.5" is the absolute widest possible! Any wider and tire contacts upper a-arm balljoint.
stock wheels w/1/4" spacers will fit 35" x 12". They WILL NOT fit 35" x12.5" as that extra .5" makes the difference. Your tire will be about 1/4" away from the ballljoint with a 34" x 12" tire WITH 1/4" spacers. Fitment is up to you. Don't hate if they don't fit.
5.5"-4.5" backspaced wheels will allow 35"x12.5" tires silght rub at full lock.
aftermarket wheels as above PLUS 2"+ lift/level will fit 36's no problems(standard width of 12.5)
All the info you need to know is above.
You'll need spacers with stock wheels to clear. 1.25" spacers are the smallest you can go that have their own studs, and that wont force you to cut down your current studs. anything between 1/4" and 1", you'll have to get longer studs or cut down your studs because under 1.25" will hit the back of the wheels.
