Key "Trick" to pull engine codes
Old Jan 18, 2010 | 12:38 PM
HammerZ71's Avatar
HammerZ71
Default Key "Trick" to pull engine codes
To pull the code, do the following without starting the engine:
turn the key to the run position, off, run, off, run.
Do it fairly quick. When you are done, the codes will show in the Odometer
as the letter P followed by 4 digits. Write them all down. When its done,
it will read 'Done'.
