Question about my 2008 Tail lights,..
I would LIKE, to get rid of the Bubble-look tail lights on my 2008 2500. I don't like the LED type lights. ( Personal preference I guess). I've heard earlier tail lights can be used? They don't have the bubble look to them.
Anyone know if they would work? And, which years would work if any?? Thanks.
I think I'm on the way to the Boneyard... U-pick-it... I can grab a older one for cheap. And start experimenting on the wiring. If, I can figure it out. AND, figure out bulb placement. I'll go for a set and do it. Thanks for the clarification on the difference!
After I set everything on fire! Lol.
I'm sorry for no follow/up in a timely manner but, I've been caught up in moving. Going on my winter lay-off. Address changes,.. Ect... The panel, or circuit board thingy in the back I gutted. The holes I carfully reshaped with my demmel tool
To accept the '08 sockets and bulbs. It worked great for the top two. ( l had to use 2 of the gray colored spongy gaskets between the socket and board for a tight seal... The third hole, the cutting disk just shattered to heck the hole completly. ( My fault). I simply got into a hurry I guess.
It can be repaired I guess by over lapping plastic and epoxy for bonding. Then, a new hole can be drilled and cut to size. It WILL work. I've not had the time to follow thru. I REALLY would like to post a pic when done. Just, need the time to get er done!
