Tranny ? 2005 SLT 4x4 1500
Old 09-16-2017, 02:11 PM
RevAl's Avatar
RevAl
RevAl is offline
Default Tranny ? 2005 SLT 4x4 1500
New here and have an issue hope I posted in the right place any help will be greatly appreciated I am older and cant really do as much as I use to do . Tranny goes into gear (forward or reverse) only after starting and sitting for a few seconds after that all is well. no leaks ,fluid is pink , shifts ball gears fine and truck has only 57000- miles. I have not checked DTC but I do know the ones that might show up.
P0868
P0944
P0731
P0736
P0841
P0876
But before having these checked can any body tell me what cooler return filter to use as part # 04799662AB has been suspect to failure .
Old 09-17-2017, 09:39 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
Need to know what codes, if any, you are actually getting.
That said, that behavior actually sounds fairly normal......
Old 10-10-2017, 10:40 PM
axeman_87's Avatar
axeman_87
axeman_87 is offline
my truck a 2006 dodge 1500 with a 545rfe was doing the same thing. until yesterday.... now it's pulling up
P0841: Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
P0700: Transmission Control System (MIL Request)
P0944: Loss of Hydraulic pump prime
So far I have changed the passenger side rear of transmission pressure transducer with no avail. I will try to drop pan and change filters (make sure filter is pushed in there) and see if that helps. need RTV first. - tomorrow project now.
But to let everyone know two years ago i had exact same issue, changed the whole solenoid pack - under valve body. changed it and filters, new oil and it has been all good since then. until yesterday. the truck has a lot of km, but the oil then was pretty good cond. no filings and color were normal, smells fine. and now it is too. I just want to find a solution without spending mega dollars.
