My Check Engine Bulb was Taken Out when I bought the truck, Look What I Found..
RE: My Check Engine Bulb was Taken Out when I bought the truck, Look What I Found..
To go any deeper into diagnosis requires the use of a DRB III that a dealer has, or a snap on diag tool might work but I have never tried the snap on tool to see if it will get you the info that you need.. I know this is sorta technical but hope it helps some
Symptom:
P0740-TORQ CONV CLU, NO RPM DROP AT LOCKUP
When Monitored and Set Condition:
When Monitored: Continuously with the key on.
Set Condition: This code wills set if the Torque Convertor Clutch (TCC) cannot achieve
the desired drop in engine RPM when the TCC solenoid is near the maximum duty cycle.
Two trips of three consecutive bad tests are required to set the code. (Vehicle not in low
range)
POSSIBLE CAUSES
CHECK FOR MISFIRE CODES
INTERMITTENT TCC SOLENOID
CHECK THE TRANS FLUID LEVEL AND CONDITION
INPUT SHAFT SEALS
INTERNAL PROBLEM OR TCC SOLENOID
OIL PUMP/SHAFT/SEALS
TORQUE CONVERTER
VALVE BODY
TEST ACTION APPLICABILITY
1 Turn the ignition on.
With the DRBIIIt, read DTCs.
Is the Good Trip counter for P0740 displayed and Equal to 0?
All
Yes ! Go To 2
No ! Go To 12
2 Turn the ignition on.
Are any of the following DTCs present?
All
P0122
Test Complete.
P0123
Test Complete.
P0743
Test Complete.
P1696
Test Complete.
P0320
Test Complete.
Misfire codes?
Go To 3
No ! Go To 4
3 Turn ignition on.
Are any Misfire codes present?
All
Yes ! Repair all Misfire codes before proceeding.
Perform TRANSMISSION VERIFICATION TEST VER - 1.
No ! Test Completed
4 Check the transmission fluid level and condition per the service information.
Is fluid level OK and clear of contamination?
All
Yes ! Go To 5
No ! Repair the fluid level and condition as necessary.
5 Turn the ignition on.
With the DRBIIIt, perform the TCC System test.
Did the engine stall?
All
Yes ! Go To 6
No ! Go To 9
6 Start engine.
With the DRBIIIt, perform the Gov and 3-4 Shift Valve System Test.
All
Yes ! Go To 7
No ! Go To 8
7 Turn the ignition off.
Replace the TCC Solenoid (part of the Transmission Solenoid Assembly) in accordance
with the Service Information.
Perform the Gov and 3-4 Shift Valve System Test.
With the DRBIIIt, select 4th gear.
All
Yes ! Repair the internal transmission problem in accordance with the
Service Information. Check for blocked passage(s).
No ! Test Complete
8 Turn the ignition off.
Remove the transmission oil pump and inspect the reaction shaft, input shaft and
input shaft seals.
Are any of the parts worn or damaged?
All
Yes ! Repair or replace the parts as necessary. Replace the Torque
Converter.
No ! Go To 12
9 Turn ignition off.
Connect a pressure gauge to the transmission cooler out port with a 9T9 connector
Start engine.
Monitor the gauge pressure while performing the TCC System test.
Did the cooler out pressure increase when the TCC was actuated?
All
Yes ! Go To 10
No ! Repair the valve body in accordance with the Service Information.
Check for a blockage or leak in the TCC hydraulic circuit.
10 Turn ignition off.
input shaft seals.
Are any of the parts damaged or worn?
All
Yes ! Repair or replace worn or damaged parts as necessary in accordance
with the Service Information and replace the Torque
Converter.
No ! Go To 11
11 If there are no possible causes remaining, view repair. All
Repair
Replace the Torque Converter.
12 At this time, the conditions required to set the DTC are not present.
Note: Use the Freeze Frame Data to help duplicate the conditions that set
the DTC. Pay particular attention to the DTC set conditions, such as, VSS,
MAP, ECT, and Load.
Note: Visually inspect the related wiring harness. Look for any chafed,
pierced, pinched, or partially broken wires.
Note: Refer to any technical service bulletins that may apply.
Were any problems found?
All
Yes ! Repair as necessary.
No ! Test Complete.
Symptom:
range)
POSSIBLE CAUSES
INPUT SHAFT SEALS
TORQUE CONVERTER
VALVE BODY
All
Yes ! Go To 2
No ! Go To 12
All
P0122
Test Complete.
P0123
Test Complete.
P0743
Test Complete.
P1696
Test Complete.
P0320
Test Complete.
Misfire codes?
Go To 3
No ! Go To 4
3 Turn ignition on.
All
No ! Test Completed
All
Yes ! Go To 5
All
Yes ! Go To 6
No ! Go To 9
6 Start engine.
All
Yes ! Go To 7
No ! Go To 8
All
No ! Test Complete
input shaft seals.
All
Converter.
No ! Go To 12
Start engine.
All
Yes ! Go To 10
input shaft seals.
All
Converter.
No ! Go To 11
Repair
MAP, ECT, and Load.
All
No ! Test Complete.
Thanks for all that great info!!!!
Well I got word back from the shop today and my cluster is bad.... They ran a scan of the cluster and it cam back failed. So I went ahead with a complete tune up brake job and all fluids changed now my next step is to get the cluster.
The shop was saying that it is very bad to buy a cluster online because they have to reprogram by the dealer and it can fry your ecm if not calibrated. I was shocked when I found out the cluster is just about or is more important than the ecm... I am so pissed right now but I am just sucking it up and knowing my truck will run another 100k after the 500$ i put into it today. Now I have to figure out wtf to do since Dodge is on strike and they can't give me a eta on parts.....
Can any of you help me out with a cluster for a 2002 5.9l 1500 Quad Cab 4x4 with power door locks and no immobilizer?????
Thanks
Thanks
