4.10 or 4.56 gears and rpm's
RE: 4.10 or 4.56 gears and rpm's
it is always best & less confusing
to find the MPH in each gear for each 1000 rpm of the engine.
This MPH/1000 rpm number
for 2nd gear tells you how well the truck will accelerate
with the lower the number the better
and ideally 60 mph would be just a bit over engine redline rpm
and for top overdrive gear the MPH/1000 needs to be at least
40 or so for good highway cruise MPG
MPH/1000 rpm
takes into account tires, trans and differential
it is the 'solid' number that you can depend on
MPH/1000 rpm
