E3 Spark Plugs
#21
RE: E3 Spark Plugs
ORIGINAL: tdmopar59
just the design... you gotta figure the coil system linking all the cylinders together and getting the right timing... a hotter ignition would just be a stronger coil and larger wires....
#22
#23
RE: E3 Spark Plugs
There is nothing complex about it. There are two valves in the head, perpendicular to them are two spark plugs. And it is just setting off two plugs with one coil pack. Read this article to learn a little about the engine you have in your truck.
http://www.allpar.com/mopar/new-mopar-hemi.html
I can tell you like to see yourself in every single thread, but if you don't know what you are talking about don't try to pass off your opinion as fact.
