DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Ram Tech (https://dodgeforum.com/forum/3rd-gen-ram-tech-65/)
-   -   Help me out guy's! (https://dodgeforum.com/forum/3rd-gen-ram-tech/144021-help-me-out-guys.html)
The Peddler Jan 25, 2008 08:17 AM
Help me out guy's!
I think I want to level out my truck. Just about everybody I see always lifts the front of there trucks, but I want to drop the rear to match the front. Is there a kit for this? Give me some info on this, because I know nothing about this kind of thing. If there is a kit let me know where to get it, also what kind of money am I looking at spending for this.
tdmopar59 Jan 25, 2008 08:58 AM
RE: Help me out guy's!
2wd? 4wd? the easiest way is prolly gonna be shackles
The Peddler Jan 25, 2008 09:13 AM
ORIGINAL: tdmopar59
2wd
kregier Jan 25, 2008 09:30 AM
Here's one from Moe's.
http://moesperformance.com/index.php...803090e0808b44
Double check with him that it'll fit your truck though as it doesn't mention a year. Although I don't think it should matter but you never know.
tdmopar59 Jan 25, 2008 11:31 AM
yea thats the dohickey i was refrencing... :D
The Peddler Jan 25, 2008 03:22 PM
ORIGINAL: kregier
That seems like what I want. Does anybody know how hard the install on this would be?
kregier Jan 25, 2008 03:35 PM
Shouldn't be too bad. You're going to need to lift the truck on the frame, support the axle with something, undo the springs, install the shackles and then reverse the process. If I was doing it I'd budget 2 to 3 hours for it. Not a complicated process, it would just take some time.
jesseh627 Jan 25, 2008 10:01 PM
Moe's and DJM both have the shackles. They advertise 2"s, but the best I can get confirmed is you'll get a 1"- 1.75" drop.
The rear of my truck is 4" higher than the front. Short of using the shackles and removing the overload springs,the only other way to drop much lower without a flip kit, which will give you 4.5-6" drop depending on the mfg. you choose, is to get replacement rear springs.
Eibach has a set they say will give you 2-3", Eaton Springs have a set that they advertise as 2" lower than stock, and Beltech has a set that say 2-3" below stock as well.
Hope all this rambling helps.
Jesse
The Peddler Jan 25, 2008 11:04 PM
ORIGINAL: jesseh627
Jesse
Where can I find these springs, and what kind of price am I looking at?
hemiman4ever Jan 26, 2008 03:58 PM
jesse is dead on.eibach makes new leafs that give 3.6 drop.try performance products.com.i've done alot of business with them and they have always been great.ask for frank or ricky.
© 2026 MH Sub I, LLC dba Internet Brands
