DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Ram Tech (https://dodgeforum.com/forum/3rd-gen-ram-tech-65/)
-   -   HOW MUCH LIFT FOR 35's (https://dodgeforum.com/forum/3rd-gen-ram-tech/147665-how-much-lift-for-35s.html)
COYOTE10663 Feb 14, 2008 01:04 PM
What is the minimum lift I need to run 35" tires on stock rims for my truck? ( see sig. below)
COYOTE10663 Feb 14, 2008 01:07 PM
RE: HOW MUCH LIFT FOR 35's
B.T.W.: IT is a 2WD
XxSilentHawk99xX Feb 14, 2008 01:08 PM
umm what sig? I dont see a picture. Anyways, you need at least a 2" leveling kit to fit 35"s....from what i believe...I am getting the Rough Country 3" Suspension lift for my truck, and I may eventually upgrade to 35"s but my 33" A/T tires are practically brand new...
oefootball_70 Feb 14, 2008 01:12 PM
my 35's rub a little with a 6 inch lift
COYOTE10663 Feb 16, 2008 10:11 AM
Thanks oe.I do not want to put a 6" lift on. so it looks like the 2" leveling kit and 33's are the way I am going to go. Accualy, the tire I have picked out for right now is the 285/70/17 KUMHO A/T.
They are $118.00 ea at tirerack.com I think that is reasonable, and they havereally good review reports too.
perfectlytuned Feb 19, 2008 07:36 PM
i think 285's are more 31-32inch tires. i think if u want 33s ull have to go with 305's
ride_002000 Feb 19, 2008 07:48 PM
ORIGINAL: perfectlytuned
285/70/17 are 32.71"
305/70/17 are 33.81"
A 295/70/17 will get you 33.26"
oefootball_70 Feb 19, 2008 10:30 PM
Mine are 305 something.
ride_002000 Feb 21, 2008 11:32 PM
Those numbers are from a tire size calculator/converter so you can trust it if you want, Im not sure how tall metric sizes are. I have 275/70/17 on my stock 2wd with no rubbing, so I imagine you could go with a 295 with the 3" lift.
Secretlover Feb 28, 2008 01:13 PM
I do not have a lift on my truck and have 35x12.50 pro comp all terrains. I have not had a problem with rubbing. I do however have a leveling kit on the front end. Also I did not lose any power from my V6 by adding the heavier tires.
© 2026 MH Sub I, LLC dba Internet Brands
