High Speed Shake
Old 03-06-2008, 10:06 PM
AZHemiChk's Avatar
AZHemiChk
AZHemiChk is offline
Default High Speed Shake
So this problem has started to irritate me more lately. I bought my truck with Goodyear Eagle LS2s on it, and I'm definitely not crazy about the tires, but I can afford anything new right now. It had a high speed shake, so I had my coworker rotate and balance all four tires. Hit the freeway, and it was still shaking. I found the warranty reciept from Discount Tire (ugh, competitors!) so I went over, they balanced the tires, found that each took about an ounce. Hit the freeway again, STILL shaking. Randy (HemiRiden) suggested that it was the driveshaft that needed to be balanced. Called the dealership, they said they not only do NOT balance driveshafts, but that 02-03 half ton rams "drive like 3500's" and will always have this high speed shake.
Is there any truth to this?
Old 03-06-2008, 10:13 PM
damram1980's Avatar
damram1980
damram1980 is offline
Default RE: High Speed Shake
i dont know if i could live with their answer of its just shaking i think its all tires, balanced corectly? how many mi on truck? im at 43,000 and its virgin tight lol
Old 03-06-2008, 10:22 PM
AZHemiChk's Avatar
AZHemiChk
ORIGINAL: ramman1980@gmail.com
LOL. It's got 53k miles on it. The tires are pretty chopped up from the previous owner driving them for so long out of balance, but Discount doesn't seem to want to warranty them out. I really dislike these tires too...too mild of a highway tread. I'd but some Bridgestone Dueler A/T Revos on there from work if I could afford it...
There's nothing mechanically wrong with the truck either. I've had it up in the air and had several people check it in addition to myself.
Old 03-06-2008, 10:28 PM
Baddog543's Avatar
Baddog543
Baddog543 is offline
I have an 02 with 95000 miles and I do not have any shakes at high speed. May want to get some things checked like shocks or your front suspension. It could be any number of things but I could not settle on someone saying that that is common.
Old 03-06-2008, 10:39 PM
bwhite757's Avatar
bwhite757
bwhite757 is offline
ORIGINAL: AZHemiChk
I think you pretty much answered your question there...
Old 03-06-2008, 10:40 PM
jm22876's Avatar
jm22876
jm22876 is offline
I had the same problem on my 95 2500...I rotated the tires and got an alignmentand the truck shook pretty bad...took it back to the shop and thethey couldnt fix it. So i put the tires back the way they were and it got rid of the shake. I know its not a good answer... but if you dont like the tires andtheir alreadychopped up...its an idea (albeit not a good one) Someone suggested to me that maybe one of my rims was bent... because when i went very slow (3-4 mph) it felt like the truck was wobbling. Also might be worth taking a look
Old 03-06-2008, 11:00 PM
big guy's Avatar
big guy
big guy is offline
Well. I think the dealer is full of **** and is just trying to get rid of you! These trucks don't shake at high speeds. At least mine never did.When I did the 4.10 gears, I started to experience some vibrations.Asa last resortIremoved the drive shaft and hadthe balance checked. Sure enough drive line guy said I had a bent drive shaft. It took quite a bit of straightening before he could balance it. Cost me $150.00. Now this had to be bent from the factory because I never hit anything. Anyways the trucknow rides assmooth asbefore when I had the 355's in it. I'd say if youchecked everything out and are down to the tires and driveshaft. Start saving for tiresandpull the driveshaft and get it checked.If itchecks outok it will not be that much money.Then you can at least rule out the driveshaft.
Good Luck.
Dan
Old 03-07-2008, 12:05 AM
RamItOne's Avatar
RamItOne
RamItOne is offline
ORIGINAL: AZHemiChk
allignment issues
ball joint
could the rotors be messed up thus having an uneven centrifugal force causing the shake
does it ever settle down once a certain speed is met?
uh maybe he really beat the **** out of it and the bead cant keep it set right (prob not)
wheel bearing issue
maybe the sidewall stiffness is not even
discout tire has road hazard warranty, keep picking up nails in the side wall.
my buddys 02 sc shakes just a bit at highway speed
good luck
Old 03-07-2008, 02:02 AM
Redram05baby's Avatar
Redram05baby
Redram05baby is offline
ORIGINAL: AZHemiChk
If I Remember Correctly, Don't You Work For Bridgestone??? Corp. At That??
And If I Am Right, Please Tell My Ex That I Can Remember Things Women Say
Old 03-07-2008, 09:27 AM
AZHemiChk's Avatar
AZHemiChk
ORIGINAL: Redram05baby
ORIGINAL: AZHemiChk
LOL oh gawd, that's hilarious. Yes I do, I'm a Service Advisor for the #1 store in the Arizona district. But even with discounts, I'm still looking in excess of $400 for tires on those damned 20" rims.
I've had the alignment checked/fixed twice. Rotors are perfect, that's another thing I checked when the truck was in the air. I'm driving this thing to Utah to see family on Saturday (ugh, Utah...cold) so maybe I'll take it to a dealership up there and just tell them to shake down the whole front end and see if they can find something I overlooked.
Quick Reply: High Speed Shake
