3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
when ever i slow down from high speeds such as getting off the highway my truck seems to shake realy bad, the bed bounces up and down and the stearing wheel shakes, the higher the speed i am breaking from then the worse the shaking is. can anyone help?
it is warped rotors. i've read in some places that rams are infamous for them. time to take it into a shop and ahve them cut your rotors. possible that your pads are still ok.
Yup rotors and possabally pads. I would nt get them turned, I would just replace them. It depends on how bad they are warped, but i would still get them replaced. my $.02
How many miles?
orig pads?
put the rotors on a lathe. Most places will only charge you 15 bucks to cut em. If you do the pads yourself, make sure you have a hammer to knock the caliper off and a C clamp and 2x4 to press the piston back in.
well its gonna cause more wear and tear on your susp depending on the shake, dont really think theyll make the tires get off balanced... if they havent been cut before just get em cut, save yourself 150 bucks easy doing that way.
