put my leveling lift on today, need bigger tires now *pics*
Old 03-12-2009, 06:42 PM
BEAR's Avatar
BEAR
BEAR is offline
Truck looks good man! A nice Rim and Tire combo would set it off.
  #22
Old 03-12-2009, 11:40 PM
dazed01's Avatar
dazed01
dazed01 is offline
I really want to keep the stock wheels I have on it. I might look into some wheel spacers I guess, not sure if they would be ok on it. I've heard bad things about wheel spacers.
  #23
Old 03-12-2009, 11:49 PM
justanothermoparman's Avatar
justanothermoparman
justanothermoparman is offline
Originally Posted by dazed01
It has 5k miles on it now, plan on taking it to the mud drags this or next month. Want some M/T tires on it
If your taking it to the mud drags I'd go with the Nitto Mud Graplers. My 0.02
  #24
Old 03-12-2009, 11:57 PM
dazed01's Avatar
dazed01
dazed01 is offline
Those are pretty expensive, I might have to save up a bit.
  #25
Old 03-13-2009, 04:38 AM
talon6's Avatar
talon6
talon6 is offline
heres mine with 17 cepeks 4.53 backspacing, and 35/12.50 cepek crushers,truck leveled only.
shows how they stick out. and this was before my steps were installed.
  #26
Old 03-19-2009, 10:10 AM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
35's look too big for just a leveling kit. They look much better on a 3" lift.
How long to add in the spacer for the leveling kit? 3-4hours not including the alignment? I would want to change the shocks to longer travel while I'm in there.
  #27
Old 03-21-2009, 12:17 PM
dazed01's Avatar
dazed01
dazed01 is offline
It took a little over an hour for putting the spacers on, I didn't see a reason to change the shocks since it's only a spacer on top of the strut assembly.
  #28
Old 03-21-2009, 02:25 PM
mfs212's Avatar
mfs212
mfs212 is offline
You will see.... I replaced my shocks shortly afterwords with some bilstiens that were a little taller. Rides awesome now.
  #29
Old 03-21-2009, 07:06 PM
dazed01's Avatar
dazed01
dazed01 is offline
If your truck is an 04 it has a entirely different suspension setup than an 08. Cranking torsion bars will raise the truck and cause the shocks to expand a bit more, putting a spacer on top of the strut assembly is doing nothing to the spring or shock. It rides exactly the same as before.
  #30
Old 03-21-2009, 08:04 PM
06 Ram5.7's Avatar
06 Ram5.7
06 Ram5.7 is offline
Dazed, how much room do you have between the suspension and the inside of the tire? Did the leveling kit give you any more clearance? Right now, there is probably on about ½” between the suspension and tire on my truck. I was looking at putting in a leveling kit and getting 35x12.5 tires. I know you can do that on a 02-05 with the right backspacing, but I’m not sure about the 06-08’s.
Quick Reply: put my leveling lift on today, need bigger tires now *pics*
