Why Does My 4x4 NOT Work?
Old Jul 25, 2009 | 03:32 PM
HoustonDodge's Avatar
HoustonDodge
Default Why Does My 4x4 NOT Work?
Welp, went to the beach today in Galveston and went to Crystal Beach and went to engage my 4x4 and the shifter moves totally free in its box on the floor. I tried it in all gears and nothing, the shifter just moves back and forth freely and will not go into 4x4. My truck is an 02 5.9L Any ideas what this could be and how much to fix it? Thanks for any help!
Old Jul 25, 2009 | 03:44 PM
Rojhan's Avatar
Rojhan
Have you checked the physical linkage?
Old Jul 25, 2009 | 03:58 PM
dirtydog's Avatar
dirtydog
Moderate User
^^ Yup. sounds like your linkage came off.
Old Jul 25, 2009 | 05:04 PM
HoustonDodge
OK HOw do I check the linkage and/or put it back on? How could it have come off? I dont do any off roading really and havent had any major bumps. Is this something I can do myself or have to have it done? Mind you, I know next to nothing when it comes tho stuff like this.
Old Jul 25, 2009 | 06:31 PM
Rojhan's Avatar
Rojhan
The manual 4x4 shift lever goes through the floor and connects to the transfer case with at least one bar/rod. They are held together with pins and clips.
Look under the truck where the shift lever goes through and it will be obvious.
The normal culprit is rust and vibration killing the pins and/or clips and the pieces coming apart.
Old Jul 25, 2009 | 10:29 PM
Bigc9164's Avatar
Bigc9164
well the problem is that you got a 4x4....haha. jk. but seriously its a linkage...i fix that all the time on my buddies jeep
Old Jul 26, 2009 | 03:22 PM
HoustonDodge
SOB! I went under the truck and yep, the linkage is completely gone! Now I wonder where I can get a new one? Junkyard? Whats the actual name of the part cause I cant find it on the net so far using 4x4 linkage. It looks like it just bolts on and I can move the shfter myself under the truck if I HAD to I guess but thats ghetto! Anyway Im glad thats all it is! Thanks for the help!
Old Jul 26, 2009 | 06:11 PM
dodge it then ram it's Avatar
Yup, check a salvage yard or a pick and pull. Pick and pull might be easier since you can just go get it and not look like an idiot trying to explain it to somebody
Old Jul 26, 2009 | 06:54 PM
sledlvr's Avatar
sledlvr
Also take a picture [ if you can ] of the linkage on the donor truck, it'll help when reinstalling it so you put it back the right way !
Old Sep 7, 2011 | 05:03 PM
pldi's Avatar
pldi
wtf, just noticed mine was missing today
