DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Ram Tech (https://dodgeforum.com/forum/3rd-gen-ram-tech-65/)
-   -   Accessories don't work with cigarette lighter outlet (https://dodgeforum.com/forum/3rd-gen-ram-tech/215780-accessories-dont-work-with-cigarette-lighter-outlet.html)
RockyRR Sep 29, 2009 03:11 PM
My 2006 RAM SLT has both a cigarette lighter and a separate accessory 12V outlet. The accessory outlet works (provides 12 volts) when I plug in an accessory; however, even though the cigarette lighter works (the element heats up when pushed in), when I try plugging in an accessory in the cigarette outlet the accessory doesn't work (no power). Any thoughts on why this might not work for accessories?
Thanks
ramhunter9 Sep 29, 2009 03:17 PM
to different sockets look inside of the two the sig is only for the sig . sorry thats the way it is .
RockyRR Sep 29, 2009 03:38 PM
I wonder why they made it that way? It used to be in cars/trucks the cigarette lighter receptacle could be used as an accessory outlet.
tomalaina Sep 29, 2009 04:03 PM
When i changed to a double din radio i also changed out the sig lighter for another power port.
EJM05 Sep 29, 2009 04:36 PM
I like the double power port.
RockyRR Sep 29, 2009 05:55 PM
Looks good.
oneHEMI57 Sep 29, 2009 09:45 PM
"Turn the ignition switch to the 'Run' position. Check for batt voltage at the fused B (+) fuse in the integrated pwr module, if ok, then ck the back of the cigar lighter outlet shell center tap for batt voltage." Main step, turn the ign switch on.
They hooked it that way so if the operator used the port for an accessory outlet, say a coffee cup warmer, and if forgotten, it would not set all day toasting.
RockyRR Sep 30, 2009 05:24 AM
Thanks, folks.
MikeHTally Sep 30, 2009 07:01 AM
Both the ones in my truck work for anything. Power is power. One is switched, one isn't.
xfeejayx Sep 30, 2009 08:26 AM
likewise
© 2026 MH Sub I, LLC dba Internet Brands
