3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I ordered my fan. I hope it arrives next week so I can install it next Sunday. What I am looking at an install time, give or take. I am guessing about an hour or two at most. It looks pretty straight forward.
Yeah it shouldn't take you more than a hour and a half at the most, depending on how much trouble you have getting the clutch fan off. Mine came right off but some have alot of trouble. Mount the fan in your shroud and the wiring is pretty straight forward.
Yep, that fan clutch nut is a "tough nut to crack". You may be able to rent a "spanner" to hold the water pump pulley still while you wrench the nut loose. It's "righty-tighty, lefty loosey", just like nearly every nut you've seen.
