3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i have a 02 dodge ram 2500 4x4,when i put it into 4 wheel drive it has a vibration and it sounds like a clunking noise,can any one help me to fix this problem?
you are probably hearing the 4x4 grind on dry pavement at turns . this is normal. 4x4 is for "sticky" situations. where the wheel will slip and you dont feel the grind ect... my recomendations dont use 4x4 on dry pavement
