Trannys, Diffs, and Fluids....
Alrighty fellas, did a quick (half-a$$ed) search, and didn't find exactly what I needed.
I'm preeeeety sure neither of my trucks have been properly maintained, by the prior owners and myself included. So now I have 4 diffs, 2 trannys, and 24 sparkplugs to replace.
I will spend the extra $ and go synthetic with everything. But my big question is this: Can I use the same fluids/weights in both trucks? I know the 'Rango is different from the Ram, but I'd imagine the drivetrain is quite similar. What weights are ya'll recommending for the diffs and tranny, in the Ram at least? Once I find that out, I can cross-reference to what the 'Rango calls for... I'm really hoping I can keep it the same for both, so I can just buy it in bulk, maybe save a $ or two.
Also, are there any online gigs that sell these oils in bulk? Or am I better off just sticking with Advanced? I live about.....1/2 mile from one, so if shipping is an issue, Ill just stick to them. But any sites ya'll can throw out would be cool.
Thanks guys.
Thanks guys.
you can buy cases of fluid on Amazon from pretty decent prices. and im pretty sure both trannys in the durango and ram are the same, which both call for atf+4. i used valvolene for that. used to run RP in the trans, but it was too expensive this time around. i run RP 75W90 i think in the diff. just check both manuals to find out what you need.
